Hi everyone, I'm the new kid on the block, my name is dan. I'm not sure how to work this properly yet so please forgive me if I've done this wrong or posted in the wrong place. I drive a 2008 megane tourer, I currently have a problem. I'm looking for some help and advice if anyone has any...
Here goes,
My air conditioning will not work. The light on the dash doesn't switch on when pressed and will not turn the air Con on.
What I've tried so far,
- Fuses in the bonnet and glove box all ok
- changed the fan resistor so now I have blowers working on setting 1-4
- I've changed the control unit as thought may be dodgy switch - no change
- checked as much of the wires behind the dash as possible for any breaks - seem ok
- pressure in system is ok
It's seems that there's some sort of electrical fault somewhere but not sure what or where. Has anyone come across this before?
Megane 2 air conditioning not working
- Stranger
- Currently Drives:: BMW X1
Re: Megane 2 air conditioning not working
Welcome along Dan and good luck getting the issue sorted
Try a search for air con in the problems / questions forum - if you've no luck finding an answer it'll help you if you copy and paste your question in to that forum
