Radio not working
Scottjh
Currently Drives:: Megane II CC 2.0 petrol
Radio not working
Postby Scottjh » Fri Dec 18, 2009 6:12 pm
Hi Guys,
The on/off button is lit up - as is the display built into the dashboard (just the background, not the letters or numbers).
I have checked the fuse in the glove box for the radio and also for the cigarette lighter and both are fine.
As is the miniature glass fuse behind the head unit when you remove it.
Any other ideas or things to check ?
Does the head unit have an internal fuse on the PCB, for example or another fuse under the bonnet for the radio ?
Scott
direstraits
Laguna III Ph2 Exception
Re: Radio not working
Postby direstraits » Fri Dec 18, 2009 9:04 pm
Might just need a reset. There is a well-known problem with certain OEM radio units not functioning below certain temperatures. I had to reset mine yesterday at -6. It works perfectly for the time being. I have a Cabasse MP3 auditorium update list model. You might need to take it out and disconnect the bigger connector, and therafter you'll need the radio code.
Scottjh
Postby Scottjh » Sun Dec 20, 2009 7:15 pm
Unbelievably, this turned out to be the case.
Disconnected it, left it for an hour and reconnected.
After putting in the code, away we went.
Cheers.
direstraits
Postby direstraits » Sun Dec 20, 2009 8:58 pm
Might work with the fuse too. Although I didn't manage to find which one is for radio. :? And I became an expert for taking radios out. :)
mikaels
Currently Drives:: 2003 MIIphI
Postby mikaels » Mon Jan 04, 2010 6:53 pm
How do you remove the radio, is there a special key for that ? Need to remove mine after battery went flat, it's asking for a code now so presume serial number is needed :(
1.4 '03
direstraits
Postby direstraits » Mon Jan 04, 2010 7:11 pm
Plug 4 nails into 4 holes on the front of the radio and pull it out. Piece of cake.
mikaels
Postby mikaels » Mon Jan 04, 2010 7:59 pm
OK thought they are screwed in or something, thanks !!!
1.4 '03
Postby davelowe » Mon Jan 04, 2010 11:13 pm
direstraits wrote:Plug 4 nails into 4 holes on the front of the radio and pull it out. Piece of cake.
This is the famous DIN tool DIY style!
rob2005
Postby rob2005 » Thu Jan 07, 2010 2:16 pm
is it the big white connector or the big black connector i need to disconnect??
Pleaseeeee help lol!
its a 07 plate meganee cc privilege if that matters
limraaaah
Currently Drives:: Renault Megane II, 1.6 16v 3DR.
Postby limraaaah » Wed Mar 09, 2011 12:30 pm
I've just had this problem after replacing the read indicator bulb! :(
Johnr6
Currently Drives:: Renault Megane dynamique 1.6vvt
Postby Johnr6 » Thu Sep 03, 2020 3:22 pm
Its the Black large connector but you can dissconnect all the connectors just to be sure.
