Page 2 of 2
Re: installing an active sub
Posted: Sun Oct 03, 2010 10:48 am
by Ommid
I ran the remote wire from the ISO on the standard headunit, which do you have?
Posted: Mon Oct 11, 2010 10:26 pm
by beatmonkeytwo
06 Update list stereo. What colour wire was it?
Posted: Wed Mar 16, 2011 10:38 am
by Brownsome
The most useful guide out there. my sub would still have been sat in the house if it wasnt for you. cheers dude
Posted: Sun May 15, 2011 12:29 pm
by Diffbuster
Andi.R wrote:did u not put the power lead through the big grommet or is it down the ide of grommet against the metal if it is good luck your car doesnt catch fire if it shorts
I agree. There is a small rubber bung on the wire loom grommet, I think it is made for the amp power wire for a factory fitted extra.
Posted: Mon May 16, 2011 7:51 am
by foadek
lovely stuff mate! took me a lot less longer than i thought it would, a few cuts and grazes on my hand but finally got there in then end.
Posted: Wed Aug 24, 2011 9:45 pm
by arran.vigar
I presume you have already done it but for those who are wondering the same question; can you wire an amp into a standard head unit? Yes it is possible.
You need autoleads PC1-601 line output connecters.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_186391_langId_-1_categoryId_165626these will give you a pre-out one red one white/black. You have to crimp/attach these to the rear speaker cables in the wiring loom behind the headunit.
As for the REM you attach this to the blue wire if unsure then use a multimeter to test which one has a low amperage output but only when the radio is turned on. If you cannot find this then an ignition live SHOULD be sufficient. But it should be on a low amperage.
Hope this helps people
Posted: Wed Nov 02, 2011 2:07 pm
by willholdsworth
arran.vigar wrote:I presume you have already done it but for those who are wondering the same question; can you wire an amp into a standard head unit? Yes it is possible.
Ok so Im having an issue finding a wire to use as the REM, Ive found a blue wire, but when I connect it to it, the head unit goes to "Mute"
Im having a real problem getting it to work or to find any wire for the remote with to connect to. You can see in the picture where ive got the blue wire connected to on the left side of the picture .... Your help is appreciated!!!
p/s this is in my 55plate meg 225
Posted: Wed Nov 02, 2011 4:05 pm
by willholdsworth
Actually im going to create a seperate thread for this, because im desperate! haha
Posted: Fri Nov 25, 2011 11:05 am
by STH
wyuen1 wrote:STH wrote:I am considering getting a sub for my megane, however i want to use the original head unit. Is this possible? Cheers
yeh its possible but you'll need to get a feed from the rear speakers as the original head unit doesn't have pre-amps like after market HU. i thinks this is what you
http://caraudiosecurity.com/shop/product/products_id/3794.html
thanks buddy for the link
Posted: Wed Oct 17, 2012 3:56 pm
by lholland421
hi can anyone tell me where there is an earthing point in the boot of the megane please ? picture maybe?
Posted: Fri Nov 22, 2013 5:49 pm
by danbrazier
Wow. I haven't been *here* for a while. Thanks for all the thanks guys, imagine my surprise when this thread is still pretty near the top! I recall my earthing point of choice was one of the seatbelt brackets? Or maybe behind a blanking plate in the boot trim. I actually have had a few cars (and bikes) since this write-up - sorry I'm vague! I'm only back here as I'm about to pick up a cheap Megane Estate for a Winter project! I'll see you around and will definitely make sure I take pictures to look at in 3 years time
Posted: Fri Oct 13, 2017 10:20 am
by stevens1975
Hi Guys.
Looking to do this on my Renault, but the image links are broken? Can anyone point me in the right direction of a guide with images.
Many thanks
James
