Hi guys
Yesterday I picked up a 225 trophy and so far very impressed with it. However the heater doesn't work at all so I was wondering where's the fuse box located, as I haven't got a owners manual. Also I heard the meganes has keyless entry, but for some reason it isn't working any ideas?
Thanks for the help in advance
Will
New owner to a ren 225 trophy
- Stranger
- Currently Drives:: BMW X1
Re: New owner to a ren 225 trophy
Manuals can be found here
Not sure if there's a specific one for the trophy but fuse box locations and contents should be same as normal.
Thanks check all fuses and seems to be fine in the glove box. Anything else I should check. No fan, no rear demister and front windscreen
- Stranger
There's also a fuse box under the bonnet, near the battery iirc
Do I have have to remove the battery? Thanks
