225 Cooling Fan
Discussions around the Mégane 225.
joshwilk
225 Cooling Fan
Postby joshwilk » Thu Apr 14, 2016 9:04 pm
Hi, I have just brought a 225. The cooling fan does not work. I can power the fan with a power probe and it works fine. I've looked at the wiring diagram on auto data for it and it says there is a relay for the fan, I took the cover off of the fuse box under the bonnet and did a continuity test from the plug the the box and all is well. Ive checked all of the fuses. When you go onto auto data on fuse boxes theres no mention of a relay for the fan and I've looked for one but can't seem to see one, I don't know if the fuse box itself has the relay inside. I have had the car up to 110 celsius on live data and the gauge on the dash seems to be about right. Can any one confirm there is actually a relay?
Sorry for it being very long winded, I'm a trainee mechanic and electrics aren't my strong point. Thanks in advance :conf
Return to “Megane 225”
