Hi Guys,
I apologies if this topic has been brought up but I went back through and couldnt find a thread on it..
I had a clutch/DMF replacement done and afterwards the above light came on.. I took it back to garage and it turns out That hadn't put the car back together properly, so after putting the steering rack back in properly and tightening all loose bolts up it felt better but not perfect..
I took it to another garage and had them use there 'hunter wheel alignment' machine on it and it turned out the 2 front wheels were a bit out, after having these realigned the light still comes on..
The code that comes up when I plugged it into computer was DF194...
Can anyone point me in the right direction to get this light to stay off?
ESP/ASR Fault Light Won't Disappear
Re: ESP/ASR Fault Light Won't Disappear
df194 - "replace computer after impact".
It doesn't look like ESP/ASR... I don't have the manual at hand, please double check this. Is it possible that they spiked/hit the airbag computer during the repair?
Users browsing this forum: Bing [Bot] and 6 guests
