I've just picked up a 225 cup today (55 plate)(best car I've owned by far!!) and cannot find how to reset the time on the clock. I'm sure it's really obvious but I cannot find how to do it and it doesn't say in the owner's manual. Could someone please point me in the right direction???
Many thanks
Emma x
setting the clock
Re: setting the clock
Just press the two buttons beneath the clock to set the time, but it is also explained in your owner's manual as it is in mine
- Ray
i do believe its different on the 225/cars with cabasse. Not sure how to set it though!!
Hi
Thanks for the reply, mine hasn't got the 2 buttons as described in the manual, I think it is because of the stereo that is mine (cabasse one) and it should be set by using this but cannot see how to do it.
Thanks anyway
Thanks anyway
Just been searching on the Dutch Megane forum, and probably you have to use the steering wheel controls to set the time
There should be a button on the top left of the steering wheel controls that should cause the hour part of the time on the display to start blinking when pressed.
Then use the +/- (volume) buttons to set the correct hour.
Press the top left button again to go to the minute part of the time and again use the +/- buttons set the correct value.
To finish, press the top left button once more.
Hope this helps
Hope this helps
Hi
That's sorted it, many thanks for your help!
x
x
Your welcome, glad I could be of help!
