I have a 225 and in the wet it really slides around roundabouts which is a real problem - i'm not talking about when i'm going fast, just normal speed (under 30 mph). The tyes seem fine but i have notice the car skliding on right hand bends - handles perfect going round left corners??? Any advice as its beginning to feel a little unsafe!
Problems at roundabout
- Currently Drives:: Megane 225
- rjacko
Re: Problems at roundabout
check the front tyres, drivers inside may be scrubbed
The tyres have a lot of tred.
Its the back end that seems to come out.
- rjacko
have you changed any tires lately? Changing just one out of the four can cause handling problems due to diameters, more noticable in a car like the 225. best changed as a pair ie fronts or rears or as a complete set.
If not tires, get your suspension checked out. Not unknown on other cars for springs to collapse, damper failure, or bushes etc, due to all these damn speed bumps littering the roads nowadays.
good luck with it
good luck with it
- Currently Drives:: 03 Megane 1.9 dCi 120 Dynamique Sport Hatch in Black.
Panoramic Roof, and loads more stuff. - Location: North Yorkshire
My first port-of-call would be check the tyre pressures then maybe a tracking check at Kwikshit
Users browsing this forum: No registered users and 57 guests
