drivers door window
johnny the fox
Currently Drives:: 54 metalic dark blue megane dci 120 sports estate 40k miles since new (my trusty tractor) owned sinced july 2010 i do about 3-4 k miles per year
drivers door window
Postby johnny the fox » Sat Mar 22, 2014 12:15 pm
Hi, ive discovered the window regulator has gone in my drivers door, hence it wont go up or down. Its a common problem. I telephoned my local Renault service who have told me Renualt uk will pay 76% of the cost so ive got to provide the remaining 24%. Ive also got to pay £50 for a diagnostic. Im puzzled as to why i need the diagnostic if it is quite clear that is the problem! Is there any garage service out there who a members of this club who can just supply and fit a new regulator without the diagnostic using Renault uk in the same way so i only pay the 24%? regards Johnny.
morganjake1544
Re: drivers door window
Postby morganjake1544 » Sat Mar 22, 2014 12:43 pm
http://www.meganeownersclub.co.uk/forum/viewtopic.php?f=2&t=21783
Have a go yourself, it's not too tricky and it cost me £35.
johnny the fox
Postby johnny the fox » Sun Mar 23, 2014 10:04 am
ok mate sounds like a more sensible idea. Just got to negotiate the door panels. :-)
morganjake1544
Postby morganjake1544 » Sun Mar 23, 2014 5:14 pm
https://www.dropbox.com/sh/355lr8566hrzhbg/gsdaHpikou/MR365MEGANE5.pdf
The above link is to the manual, see page 15.
There are also videos on You Tube and Ebay.
Postby AlexB » Mon Mar 24, 2014 3:11 pm
Temic controllers for window regulators are about £25 on ebay, the job takes about half an hour.
johnny the fox
Postby johnny the fox » Tue Mar 25, 2014 1:43 pm
hi mate, so I don't have to buy the genuine part then? I was looking on car part 4 less and right hand door window regulators are £65 and the near side £59. I will have a look, cheers Johnny.
morganjake1544
Postby morganjake1544 » Tue Mar 25, 2014 5:12 pm
http://www.ebay.co.uk/itm/RENAULT-MEGANE-WINDOW-MOTOR-REGULATOR-MODULE-REPAIR-TEMIC-12-MONTHS-WARRANTY-/251270963983?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a80eaa30f
Remove the controller, send it to the above chap. It will be returned within 48 hours, repaired and g'teed for a year and you will retain all the original functionality, for £30.
You can phone him if you have any problems removing or refitting the part and there are photos and links to videos to guide you through it.
I have no affiliation with him but he repaired mine and the service was first rate so I would recommend the service.
johnny the fox
Postby johnny the fox » Tue Mar 25, 2014 7:05 pm
ok, thanks mate :-)
FOOTBALLGETTO
Currently Drives:: Megane II 1.5 DCI OASIS 2006 55 PLATE.
Postby FOOTBALLGETTO » Wed Mar 26, 2014 10:28 am
My front passenger window stopped working. I used the same guy to repair my module. I had it back in 48 hours and it worked a treat. It cost me £30.
Regards
Tony
johnny the fox
Postby johnny the fox » Thu Mar 27, 2014 2:01 pm
cheers mate ;-)
Phil and Liz
Postby Phil and Liz » Sun Mar 30, 2014 5:42 pm
my 08 windows stopped and i removed the panel stripped out the wiring cleaned and wd40'd it, connected back up with the panel off and it worked. Put it back together and most of the time it works.
Phil and Liz Jackson
Lanark
Users browsing this forum: No registered users and 43 guests
