Hi all,
I'm due a few days off in a weeks time to sort out the condensation/damp/water in my wife's Megane II. I've read up on the foam deadening causing a few problems.
Was wondering if anyone has removed carpets, removed foam and then put the carpet back without foam? The way I see it is the condensation is a symptom of water in the foam however it makes identify the source of leak causing it more difficult..
Anyone tried this?
Sam
Foam under carpets
- samdavisMG
- Currently Drives:: (Fiance's car) 2007 Renault Megane 1.6 16v
2008 Fiat 500 Sport 1.4 16v
1973 MGB GT
- Rally Driver
Re: Foam under carpets
Most leaks come from the drains under the scuttle panel been blocked, check these first
Users browsing this forum: Google [Bot] and 21 guests
