Hi to everyone, this is my first post, I hope you can help.
We have a dynamic coupe 2006 1.5 diesel
We have been hearing a swoosh of water under the bonnet for a while, and found out the drainage tubes were blocked, so we unblocked, and the water drained away.
but a few days later the radio packed up, then a few days later it all went weird
couldn't start
windscreen wipers going
steering look message
air bag message
and other message's
looked on you tube and said it might be ECU, and also to clean a circuit board situated under the fuse unit, under bonnet.
I managed to get battery out, remove ECU, but jut could not see a way of getting to the fuse board.
Could anyone please advise or let me know a youtube vid to watch.
Mike
Electrical problem
Re: Electrical problem
I had a load of problem last year, my 1.9dci kept conking out and sometimes wouldn't start, I bought an OBD reader and that wouldn't show a fault yet it would have "Check Injection" on the dash display, so I figured it must be the ECU I looked on eBay with every intention of buying one but I sprayed WD-40 into the ECU lead, reconnected it and it's been fine ever since
Users browsing this forum: No registered users and 49 guests
