Relay
Laurr007
Currently Drives:: 2000
Relay
Postby Laurr007 » Sun Jun 18, 2017 9:40 pm
Hello... I have megane mk2 1.9 dci 130 hp I need to know which one is the realey for protection injection and mass air flow sensor.....Fuse : + feed for main injector relay (238)air flowmeter feed protection 799).... I don't know what colour have... There are 6 relays.... 2 brown.... 2 grey and 2 pink.... Which one is?????
grandadbobby
Re: Relay
Postby grandadbobby » Mon Jun 19, 2017 1:57 pm
don't quite understand, what is wrong with car ?
Bob.
Laurr007
Re: Relay
Postby Laurr007 » Thu Jun 22, 2017 3:57 pm
I diagnostic the car and I have the code Df039 and Df056.... I checked with multimeter the socket what is plugged in mass airr flow and I have no power 12v..in dashboard is coming out the message check injection.... And the engine don't run good...it's some realey for mass air flow sensor and injection protection?
grandadbobby
Re: Relay
Postby grandadbobby » Thu Jun 22, 2017 8:09 pm
DF039 airbag/seatbelt driver side circuit
DF056 injection, air flow sensor circuit
l also can't find where 12v feed comes from. Haynes manual is useless and nothing on the net.
You will have to follow wire back to source, but l have a feeling it may go to the pcm.
l would look there for corrosion or bad contacts at connectors.
Maybe as a test, you could give the maf sensor a live feed from battery and see if it runs better.
lf l find anything to help l will post again.
Bob.
Users browsing this forum: No registered users and 55 guests
