Hi everyone im new to this forum and im need some advise.
I purchased a 2004 megane 1.9dci 2weeks ago and have had trouble every since i bought it. Ive had the adr/esr lights up the windwipers going on there own also the hazards coming on by there self! Ive found the problem it is with the fuse board under the bonnet corrorid and has traces of water. Ive been to renault and they want to charge me the earth. Does any1 know where i can get a fuse board? also renault said that it has to be programmed by themselfs is this correct or can any garage do this?
Thanks hope some1 can help me with this problem
kadders
Problems
Re: Problems
If you dry out the board and remove all corrosion, nothing needs reprogramming.
A new board would be expensive and the programming could in theory be done by anyone with a CLIP computer setup. Search the site for CLIP.
- Currently Drives:: megane estate 1500 Dynamyque DCI
Re: Problems
hi cadders 12,i bought a 1.5 dci last month and i had a starting problem.it was the fusebox under the bonnet and just had it done yesterday.my local autolecs are called motolec and they diagnosed and repaired it for £274 all in.if that cures it as they 100% say it will i,m happy.how can the fusebox get so wet?it should be well away from water shouldnt it? mine was wet,green and corroded inside.wonder how many more had this problem.i wouldnt go to renaults mate, ask locally and find a good autolecs nearby.i,m lucky motolec is only a mile away.good luck anyway,hope you sort it.ade.
Re: Problems
There are various online file "convert to mp3 file that can convert files to MP3 format, which can be useful for individuals who want to listen to audio files on devices that don't support the original file format. However, it's important to use a reliable converter to ensure that the audio quality is maintained during the conversion process.
Users browsing this forum: Google [Bot] and 104 guests
