Evening all,
Hope everyone had a nice christmas.
Anyways I seem to be having a constant problem with wiring on the front o/s, the basics of the problem is that the front o/s indicator works fine for a while then all of a sudden for no reason the o/s indicator light stops working.
We can use the right turn indicator with no problem still however it flashes as normal once or twice before going like a bat out of hell. Initially thought it was a problem with the bulb however after going through a few bulbs in a very short period of time, I pulled out and replaced the headlight and bulb however this has not sorted out the problem.
Does anyone know what the problem could be as not only is a hazard but both a problem for both us and other road users.
Our car is a 3 dr 53 plate 1.6 Megane Dynamique.
Many Thanks
Problem With Wiring On Front O/S.
- Currently Drives:: Renault Megane Mk2 Dynamique 1.6 16V
By Failing To Prepare, You Are Preparing To Fail - Benjamin Franklin
- Ray
Re: Problem With Wiring On Front O/S.
i vaguely recall its a common problem on the early models to do with the wiring loom
Remove the bumper, then the headlight, and investigate. Be prepared to repair a connector, so have a needle file and silver conducting paint at hand. Removing the headlight and putting everything back together takes under half an hour, another half an hour will be spent on fiddling with the contacts.
Many Thanks for the replies so far, its greatly appreciated.
Will have to take a look over the next few days and see if I can resolve the issue.
