airbag+service lights
meganejan2014
Currently Drives:: 2003 megane 1.9 dci dynamique
Postby meganejan2014 » Thu Apr 17, 2014 4:25 pm
hi my airbag and service lights come on every time I move my drivers seat , is there a common wire that breaks , I can see a sensor or some thing through the seat belt hole , but messing with that doesn't seem to help , anyone else had this issue ? any idea's on solving it ?
thanks jan
Last edited by meganejan2014 on Thu Apr 17, 2014 11:43 pm, edited 1 time in total.
2003 Megane Hatch 5dr 1.9 Dci Dynamique blue 86,000
morganjake1544
Re: airbag+service lights
Postby morganjake1544 » Thu Apr 17, 2014 6:34 pm
There's a connector under the seat which can work loose. That would be the first thing to look for.
meganejan2014
Postby meganejan2014 » Thu Apr 17, 2014 7:06 pm
yeah I gave that a giggle and the first time it worked but it is in solid now and is still doing it , thanks for the reply
can I just unplug it without worrying about a airbag popping in my face do you know ?
morganjake1544
Postby morganjake1544 » Fri Apr 18, 2014 11:14 am
Have you checked the connector under the passenger seat as well?
Yes they can be unplugged safely BTW.
meganejan2014
Postby meganejan2014 » Fri Apr 18, 2014 11:31 am
no it is defiantly around the drivers seat area , there is a wire I have noticed under the seat hanging that comes from the sensor on the seat belt , I am going to check that for breaks today , just a bit worried about setting off whatever its connected too , need to trace it to see if there is a plug on the other end . and thanks again
meganejan2014
Postby meganejan2014 » Fri Apr 18, 2014 1:08 pm
Just thought I would let everyone know my findings , whilst messing with the above mentioned sensor and fiddling around under the seat , I came across two wires separate to the loom wrapped in the black materiel stuff under the seat , they go to a second sensor/box on the other side of the seat , these are the culprits one had got court at some point in the seat mechanism a quick repair job and off went the lights , I am going to go an tie them up out the way , but well worth checking yours to see if there the same , as you can prevent this from happening to you before its to late :rock
Users browsing this forum: Bing [Bot] and 68 guests
