Looks like a plastic cable sleeve for something?!
This as well that is unplugged from something?
Wondering if this could be linked with my none working Parking sensors?
Anyone know what this is
Re: Anyone know what this is
Battery vent pipe. Its end is clipped to the front bottom part of the left front wheel arch liner. The other end goes into the battery.
Thanks Alex, just the cable and plug now to work out
aldo wrote:Thanks Alex, just the cable and plug now to work out
Tyre pressure sensor pick up - dependant on model...
I have a 2005 Scenic with these installed - the magical bit is in the wheel assembly itself - The sensors are mounted in the wheel area - it they go wrong I think the fix is to unplug them... Put a bag on the plug and tye-wrap it by the sound of your issue...
Will
2005 Scenic 1.9Dci 120 Exception
Thanks.
It's a Megane GT 07 plate.
When I start the car, the car symbol with the tyres comes up ok. It's odd though as when I got the car, they all had different pressures in the tyres, some low as 22 psi.
Will check out and take another wheel off and see of that's disconnected too.
Got some more, anyone know what this is.
Trying to investigate why the rear parking sensors aren't working!
That was found when I removed the engine fuse box!
Also this plug was next to it
Again both not plugged in.
One I guess might be for the tyre pressure sensors, the other one?!
Couldn't see where they would plug in to either...
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 37 guests
