regenerate soot filter message
Posted: Wed Feb 04, 2015 6:38 pm
by bambam
Hi all,
Got a message appear today about regenerating the soot filter, does any of you wise bods know how I go about this as I have never come across this before.
Its on a 1.9 dci estate if that makes any difference.
Many thanks in advance Geoff.
Re: regenerate soot filter message
Posted: Wed Feb 04, 2015 7:12 pm
by Wickydude
Usually that means the ecu has not been able to perform the regeneration cycle for a while, and you need to drive it at a constant speed of 80 km/h (is that 50 mph?) for a good time, say half an hour. happens mostly with cars that just do short trips.
Other than that, it's a visit to the dealership, they can do a forced regen.
Posted: Wed Feb 04, 2015 11:12 pm
by bambam
cheers wickydude, I will do that tomorrow.
like the idea of it being fitted to "save the planet" and then after drive further and faster to clean it out.
must make sense to somebody.
Posted: Thu Feb 05, 2015 6:37 am
by bambam
Problem solved
15 miles at over 3000rpm and message disappeared,
seems to me to be a counter productive exercise but hey ho what do I know.
Posted: Thu Feb 05, 2015 9:49 am
by Wickydude
It still filters out the small soot particles.
Normally when you drive, you don't notice the regen, it's just when it can't finish the process for an x number of times, it will throw an error. Short trips no good
Posted: Fri Feb 06, 2015 7:27 am
by antonyd45
hi
make sure you use the correct oil I kept having this message and eventually my dpf was completely blocked Renault said I should be using 10w 40 or 5w 40 in my 1.9 dci megane
I had a new one fitted and a week later I had the regenerate soot filter message again so I searched the internet and found out I should have been using 5w 30 full synthetic oil so I changed it and haven't had that message in over two years .
hope this helps.
Posted: Fri Feb 06, 2015 7:38 am
by Wickydude
Yeah full synth, but must also be compliant with acea c4 spec. Or Renault 0720 approved (same thing really).
Posted: Fri Feb 06, 2015 7:58 am
by bambam
Morning,
Yeah its due a service so will make sure I use that oil,
Thanks.
Geoff.
