1.5 dci 04 plate 5 door no mods
Just had track rod ends sorted, cv gaiter and a new washer pump. Done Monday.
So I drove 200 miles wednesday ( 5 hour constant) in one hit and then anoth 100 in short trips and then set off on the 200 mile trip home. 30 miles in, Rev counter and temp gauge stops working, but speedo and petrol gauge fine, service light comes on and display says electronic fault. Check my OBDII reader and nothing showing in faults (I do not think it's compatible with the 1.5dci) rev readings on that show normal along with engine temp. Driving fine.
I pull over at the next services, check the battery voltage, reader says 13.8 it normally says 14.2.
Turn off car.
Try to turn car back on and nothing, not showing fault anymore my no turning over and all dash lights on.
Turn it off, take card out wait 30 seconds and I tried again
Started straight away no issues, not errors messages no issues
Continues the rest of the way home no issues and no issues today.
Any ideas???
Electronic fault
- Currently Drives:: Owns but can't drive Renault megane 1.5 dci 04
Re: Electronic fault
Oh and when it did turn back on it had reset my trip counter and Subsquent readings.
Georginasweeting wrote:... it had reset my trip counter and Subsquent readings.
When the battery voltage drops below a certain value, that will reset the trip and other counters. It happens to mine sometimes on very cold mornings.
Rebuild the fuse assembly at the positive battery terminal and check the PSU for moisture.
The counters are usually resent if the power supply fails at some point. The above parts are responsible for the electrical power.
About a year ago my Megane dropped into limp mode with the message Check injection, tested it on an OBD machine and there was no fault, happened several times and started cutting out and not starting for a minute or so, anyway, long story short I thought it was the ECU, looked on ebay and could get one for £30, tried to take mine out, took two nuts off disconnected the 3 leads but couldn't get it out so I sprayed WD-40 into the leads before I reconnected them and have never had a problem since.
