Hello.
Hope to find the answer here...I live in the Netherlands but no one seems to know the answer.
Hope my English is not to bad.
When the ignition is on I got no +12v on the fuelpump,but with a bypass it works,so not broken or bad earth.
Wiring is also ok.
Immobilising is off.
The ignition coils get also no +12v.
The fuelpump and ignition coils get the cuurent from the protection and switchingunit.
This one I changed for another one,but still the same.
All the wiring is ok and all the earth also.
On the upc(protection and switchingunit)there are 2 points for +12v.
These are constantly +12v which is ok.
In the upc unit are 2 relays that work on -12v.
Seems to be that I got no -12v on the points ......connection P2 and the one with the big bolt.
Everything else works.....wipers,lighting,windows.....
The engine cranks when starting but wont fire up.-12v is at connector PEM TRACK 1 and 2(connection 1AC and 3 AA)
The wiring of these 2 goes to the injection computer ,the brown connector track D4 (3AA)and the big black connector track D1(3AC).
The wiring is ok,also all the fuses.
Any ideas?
Thnx......
No current on fuelpump ignition on
- Currently Drives:: Megane 2 1.6-16vvt K4M760 2005
