Stop light , brakes light and more
Hi guys n gals, I'm new to the Renault world, looking for some help and advice, I have purchased a 54 plate megane dynamique , unfortunately the dash has lit up like blackpool tower lol, I have asb light on , airbags light is on , the handbrake light and the stop light , I used the reader for codes, it only highlighted the cam sensor which I duly cleared with no difference to the car, any ideas on the issues, thanks , gary
- Stranger
- Currently Drives:: BMW X1
Re: Stop light , brakes light and more
Have a look / feel in the passenger wheel arch, there should be no hole, if there is a hole the cover is missing and it's very likely that water has got in to the fuse box and / or uch.
Do searches for water ingress, wheel arch cover, fuse box and such like, you'll get lots of results.
Pug 307HDI90 1.6 (family car)
Gary is your car a mk 2 or mk 3 (2008 could be either.) Petrol or diesel? Engine size? For advice to be given all this info is required. Does the car start and run? Airbag light could be broken clockspring (rotational connector behind steering wheel hub) ABS light could be a faulty sensor. To sort this lot out a cheap little code reader will not help. It will not be able to make contact with the injection computer, the ABS computer, the airbag computer. the multiplex system or any of the other computers in your megane. It will not even show that the warning light is on!
Cheers Mike
Cheers Mike
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 80 guests
