My wifes Megane has a sony after fit radio which has been working fine until last week. I have checked the voltages with a volt meter and the ignition live is 12v no issues but the permanant live for the radio memory ect only shows 2.5v. When connected correctly the radio will not power up but when i connect both the live cables from the loom adapter to the ignition live feed the radio comes to life as normal.
I have checked the fues in the radio and the fuse box and both are fine. I even changed them for new ones to be 100% sure. I dont want to use the ignition live feed to supply both radio live requirments as the radio will not hold its settings ect.
Any ideas if this is a simple fix or would i be ok to find anothe live feed and adjust the connections.
Many thanks
Darron
Megane CC 2006 Radio Permanant live feed only 2.5v
Re: Megane CC 2006 Radio Permanant live feed only 2.5v
l reckon you would be better off feeding on auxilary, then it will work on position 1, don't need ignition on. ( cigar lighter )
Bob.
Bob.
That was one of my thoughts. Many thanks
Users browsing this forum: Bing [Bot] and 74 guests
