Hello,
I have a megane 2005 and i have a problem with back window switch. when the switch is pressed down, the window moves down and when the switch is pulled up, the window continues to move down. i cannot use the switch to close the window. have to use the central console of the driver.
i have noticed also that the other back window is starting to have same problem from time to time.
Can you suggest what is the problem and a probable solution please. Thanks.
Rear Window switch Fault
Re: Rear Window switch Fault
chances are it's just connections, probably at the switch being's the central one works it.
Look on youtube, doesn't matter what make of car, you should see something.
Good luck
Bob.
Good luck
Bob.
Users browsing this forum: Bing [Bot], Google [Bot] and 48 guests
