I have a 2008 Megane 5 door Dynamique that shows all doors are open on the dashboard even when they are shut. Remote locking with the key fob does not work. It’s a 1.6 petrol with around 60k on the clock.
I have disconnected the multiplug on each door and cleaned the contacts but no luck. Also I disconnected all 4 doors and left the boot connected. The car then locks fine from the keycard. I then connected the rear doors 1 by 1 and it still locked fine. Then i tried the front 1 by 1, whichever I have connected gives me the fault again. Would be usual for them both to be faulty?
Any suggestions / tips appreciated.
Megane 2008 won't lock
Re: Megane 2008 won't lock
according to the wiring diagram in my Haynes manual, the front door locks are connected by a white wire.
Maybe only one is faulty but affecting the other.
There's not much about it on you tube but it seems plastic bits can break off in the motor mechanism.
Good luck and let us know if any success.
Bob.
Bob.
