Hi everyone! I'm a new member. After hours of research I've come here for your expertise.
I'm the owner of an 08 Megane II Convertible. 40k on the clock and frequently serviced, recently passed it's MOT.
However, the problem I'm having is a constant humming sound (sounds like it's coming from O/S rear) which get's louder and of and higher pitch when speed increases. This sound remains when clutch is held down and when the car is in neutral. The sound goes, at least and little bit, with a turn to the right. I've noticed it 'goes off' with a 45 degree turn to the right, or more.
Wheel bearing seems like it may be the culprit but I can't help but feel that the non-matching rear tyres may be the issue, although tread and wear appears fine. Also, there's nothing odd when throwing a trusty bucket of water at each wheel after a good run.
So, members of wisdom, what are your thoughts? ...and thank you in advance.
Constant Humming/Droning Megane II
- Currently Drives:: Megane II 1.6 Convertible
- q292u
- Global moderator
Re: Constant Humming/Droning Megane II
Rear wheel bearing?
Should I expect it to be on the O/S as the noise disappears when turning right? I guess that's due the reduction in weight on the wheel because of the shifting of the car? Thank you
- q292u
- Global moderator
I think that's more to do with front wheel bearings?
Mother in law in boot?
Original wheels?
No, she's in the boot of the old one
Original wheels, yes. I've also noticed a peculiar metal on metal slight clicking/knocking when reversing... particularly when locking to the left...
- q292u
- Global moderator
steve-t wrote:Mother in law in boot?
Users browsing this forum: No registered users and 42 guests
