i had an issue with the drivers window on my wifes megane, it was stuck halfway down. i removed the tepic from both drivers and passengers sides and installed the passenger one on drivers side which enabled me to close the window. I ordered a replacemet from ebay and fitted this tonight but the passenger window is not working. i know the regulator is fine as was working previously. Have i missed a reset procedure before i rip both doors apart again to check whether it is a dodgy unit
thanks in advance for your thoughts on this matter
megane cc window issue
Re: megane cc window issue
ln my experience
They can drive you nuts.
You need to thoroughly clean all contacts in the temic etc with fine wet and dry and where possible slightly twist the lugs.
Then be prepared to do it next year too.
lf you find when done, they only move bit at a time, take all the way down and hold switch down 30 secs to reset.
lf that doesn't work, do the same on the up.
Good luck
Bob.
ln my experience
Good luck
Bob.
thanks for the reply i stripped the door down again and discovered that the connector wasnt fully home silly me. that will teach me to rush to get it done before nightfall
Users browsing this forum: Google [Bot] and 41 guests
