Air Con Problem
Air Con Problem
Hi I am having trouble with my air con, I drive a 2006 16,16 VVT privledge megane 2 it has climate control and air con.
I had it regassed but no joy I can get compressor to work by powering it separately with a indepentant power source but engine struggles at tick over,
Is it the Engine or interior multiplex unit with controls the air con, I see Engine multiplex,s on EBay but there are so many different models which is right for me...
Hopefully there should be a picture of mine...
thanks in advance
Re: Air Con Problem
[img]<a%20href="https://s1376.photobucket.com/user/scooper1000/media/fuse%20box_zpss4suhbad.jpeg.html"%20target="_blank"><img%20src="https://i1376.photobucket.com/albums/ah13/scooper1000/fuse%20box_zpss4suhbad.jpeg"%20border="0"%20alt="%20photo%20fuse%20box_zpss4suhbad.jpeg"/></a>[/img]
[img][IMG]https://i1376.photobucket.com/albums/ah13/scooper1000/fuse%20box_zpss4suhbad.jpeg[/img][/img]
Sorry but forgot how to post pictures one of the above should work....hopefully
- Currently Drives:: megane sports tourer
Re: Air Con Problem
I think the compressor won't kick in if
The pressure switch does not detect
Pressure. Perhaps the problem lies
There
There
Re: Air Con Problem
Where would I locate that please and is there a way of testing it.....
- Currently Drives:: 2004 Megane MKII 1.5DCi (80)
Re: Air Con Problem
I have a leak in my system so air con doesn't work either. I think it's the high pressure pipe on mine which goes to the bulk head.
Anyway, supercool stop leak seems to be an option to find the leak yourself. I've never used it but you'll need a uv torch (couple of quid in eBay). If anyone has used it maybe they can suggest how effective it is.
Re: Air Con Problem
Mine has not got a leak as I can get it blowing very very cold by running a wire direct to compressor but Engine gets lumpy at tickover due to lower revs....hope you sort your leak out...keep us informed
Users browsing this forum: Google [Bot] and 64 guests
