Hi, Just bought a Megane II as a first car
Its a 1.5 dCi Dynamique, and its not in great condition. There is slight black smoke from the exhaust, and an OBD reader shows the P0381 error code, can I assume those two are linked? The MOT also mentioned an oil leak from the turbo, so would I just need to replace one of the glow plugs, or the glow plug relay, or need a complete turbo rebuild?
Would appreciate any advice
Smoke from exhaust + OBD Error
Re: Smoke from exhaust + OBD Error
the two are not linked.
The glow plug circuit p0381 could be a glow plug gone, if you find all the glow plugs are working (see you tube for testing) and it starts ok, it might be a thermal plunger not to worry about.( they are like glow plugs in the cooling system for if you live at the north pole )
The black smoke, did it fail the mot, is it all the time ?
lf it's just on acceleration and passed the mot you could check the air filter, after that, it's clogged inlet manifold or maybe injectors, but there, you are getting into heavy stuff, beware !
The oil leak at the turbo depends how bad it is. lf it's throwing it into the air intake you'll get blue smoke and burn oil quite quickly.
lf you've just acquired the car and it's passed the mot, l would run it a while and see if it's worth spending money on.
Good luck
Bob.
Good luck
Bob.
grandadbobby wrote:Hi,
Good luck
Bob.
Thanks for the quick reply
I have just got the car, and it is not even insured, so I've only had the chance to go around the block. It passed the MOT and only advisories were the tires being below limit, and the turbo oil leak. It happens on acceleration only I think, so I will try what you said I havent seen any blue smoke so I hope its not a serious leak
Hi Nahr,
if there's no oil dripping on the floor, it may just be a clean up and need oil change.
Good luck
Bob.
Good luck
Bob.
Users browsing this forum: No registered users and 105 guests
