Hopefully someone can help.
Today on the motorway i was doing 60 with my foot down and the injection fault light came on and it has no power (limp mode i think). Gears 1,2,3 and 4 seemed okay but gear 5 seem to have no power. I replaced the EGR valve a few weeks ago and i think i didn't tighten up on of the pipes coming off it, i tightened it up and the power restored and it seemed back to normal, however, after travelling at 60 in 5th it came up again but no lose of power nothing it popped up for about 3 - 5 seconds.
I'll keep an eye on over the next week and hopefully it will be okay as i need to travel from Scotland to Manchester and the week after Scotland to Durham.
Injection Fault
- Currently Drives:: Renault Megane 1.5dci
Re: Injection Fault
you don't say which engine you've got, but in any case you could do with reading what fault code has been registered.
Very important to aquire a diagnostic tool if you want to do stuff yourself.
lf you get one, make sure it does body and engine.
When you've got a fault code you can post on here and search on the net to put you in the right direction.
Good luck
Bob.
Good luck
Bob.
Re: Injection Fault
grandadbobby wrote:Hi,
Good luck
Bob.
It's a Renault Megane 2004 1.5dci.
I have a reader but it only reads one code but says N/A as the code.
This is the reader i have got https://www.amazon.co.uk/Stoga-CAN-BUS- ... bd2+reader
I found it so thats why i have it but it their is a better one for a reasonable price then i am open to buying it.
Re: Injection Fault
Anything electrical will give a fault code, sensors, glow plugs, injectors etc.
lf there isn't a fault code, in my experience it's usually fuel related, clogged filter, air in system etc.
Bob.
Bob.
Users browsing this forum: Google [Bot] and 116 guests
