Hi all
Renault megane priveledge 06 plate
I turn the steering wheel and I am now getting a clicking noise as it straightens back up ?
v annoying....any ideas ?
cia Nick
steering wheel clicking
- Currently Drives:: a renault megane mk 2 1.4 16 valve 53 plate authentique
Re: steering wheel clicking
i had same problem i had to change the part were the stalks are as there is a nylon tape that controls it if this breaks or moves you get this noise they are very expensive to replace between 150 - 300+ if you go on you tube and type in why is my steering clicking on mk2 megane you will see what part i mean
- Currently Drives:: Renault Megane Privilege 2.0L convertible hard top
will this affect the performance of the car ? or fail the MOT on it ?.......if it poses no danger I might just leave it
thoughts ?
thoughts ?
i'm not to sure if its an MOT failure i changed mine just be on the safe side
lf the horn works and no airbag light on, it may not be the squib, possibly just the turn indicator mechanism.
Bob.
Bob.
Users browsing this forum: No registered users and 83 guests
