No power in gears and loosing speed going up hill and on flat rds
- Currently Drives:: 55 plate, 6 gear convertable megane, diesel
Hi, having issues with lack of power/speed...started off with warnings 'regenerate soot filter' and 'check injection' ive had it checked etc had a part changed which helped for a while and was told my model doesn't have a soot filter? This was a few months ago..it was intermittent now it still says ' regenerate soot filter but not check injection and the kids of power and speed is constant... 55plate tdi privelage convertable megane..any ideas??? Also my temperature gauge on the clock display has disappeared and when I lock my car the beep lasts for about 5mins..
Re: No power in gears and loosing speed going up hill and on flat rds
Hi Trace,
l'm afraid it's no good just trying to guess what's wrong with your car.
lt needs diagnostics to have fault codes read and you possibly need to know if it's had a dpf removed but not deleted from the computer.
Bob.
Bob.
- Currently Drives:: renault megane 1.6
hi, have you checked the clutch, maybe its on it's way out.
Users browsing this forum: No registered users and 80 guests
