airbag and service light displayed
- Currently Drives:: a renault megane mk 2 1.4 16 valve 53 plate authentique
i have an 53 megane and recently the airbag and service light are lit up constantly i have tried to remove them by following youtube videos but to no aveil can any one help
Re: airbag and service light displayed
you need a code reader to see where the problem is. A decent one will say which airbag or circuit is affected. Don't make the mistake of using one that only does the engine, needs to be for body electrics also.
Bob.
Bob.
- Currently Drives:: Megane II 1.5 dci 86 3 door
If you haven't got access to a code reader then it might be worth cleaning the connectors under the front seats as a starting point. Disconnect the battery and leave the car for 30 minutes to allow any charge to dissipate.
Then clean the contacts with some spray cleaner and a stiff brush.
Hopefully having the battery off should reset the fault after.
That was the usual suspect on previous cars due to wires moving when the seats moved back and forth.
I've also had issues with the steering wheel contacts but that can be fiddly.
- Currently Drives:: Renault Megane Privilege 2.0L convertible hard top
I had the same. It was the connection under the drivers seat. It gets disturbed when the drivers seat is moved back and forth i.e when the wife drove it she always moved the seat.
Switch off engine....move drivers seat right back....then you will see the wires in the flooring, just take out and remove from connector..then put them back. That should sort the problem
thanks to all the guys who replied i will be looking under the seats asap most people i have spoke to say check wiring under the seats
- Currently Drives:: Renault Megan cc 1.6 black with black leather
On mine it was the streering wheel squib that needed replacing about £100 off of eBay hour to do and light went out as soon as I put ignition on
Users browsing this forum: No registered users and 71 guests
