Hi, looking for some help, trying to find out whats wrong with my Megane so i can get some quotes,
driving to work started spluttering juddering, got to work called out breakdown, when idling was fine but 'dull' noise coming from underneath.
no fault codes .. no warning lights.. breakdown man thought cat had collapsed but exhaust still doing its job. another guy came to look thinks it is plugs and coil pack but would that cause the rumble underneath ?? sorry so not mechanically minded.
help
Re: help
anything electrical, coils etc, would give a fault code.
Sounds like it could be exhaust, but with you not being mechanically minded, you need an experienced mechanic to look at it.
Check around for a decent independent garage or mobile mechanic someone can recommend.
Good luck
Bob.
Good luck
Bob.
Users browsing this forum: Google [Bot] and 77 guests
