Front Driver's side headlight
- Currently Drives:: Renault Megane Mk 2 Dynamique 1.9L (Diesel)
Hello,im looking to replace my bulb on the driver's side headlight but im having a bit of a problem the casing that the bulb sits in seems to be broken,and the spring has gone. Is there anyway for me to fix it in without buying a new one or will i have to buy a new one.
Re: Front Driver's side headlight
you need to loosen or remove the front bumper and take the headlight out.
Bet your boots the spring is probably lying there somewhere, but once you've got the light out you will be able to see what you've got.
lt's not a 5 minute job so renew all the bulbs while you're at it.
Pictures on you tube and various forums will help you.
lf you can't do without the car, if you think it's all broken, might pay you to just get a used unit to replace it first.
Good luck
Bob.
Good luck
Bob.
Thanks for your advice bob much appreciated. Shall change all my bulbs at one time if thats the case.
Users browsing this forum: Google [Bot] and 121 guests
