Knocking/ticking on turning and proportional to speed
Posted: Wed Nov 29, 2017 6:41 pm
My trusty Megane II 1.5DCi year 2005, 132k milage, has the following symptoms:
For the past few years it was clunking over speed ramps (possibly the top strut bearings), however lately this disappeared.
In the last few months it developed knocking/ticking while turning a tight corner and especially from a cold start. (CV joints?)
On Saturday I had the motor over some seriously bad rural farm tracks albeit dead slow and since then:
The Megane is knocking with one tick per wheel revolution and therefore proportional with speed... Although with constant acceleration or constant braking the knocking disappears. If in neutral the knocking is loudest and at constant speed in any gear the knocking is audible. The knocking can be slightly felt through the steering wheel.
The symptoms have gotten worse very quickly in a few days with little mileage.
Last night I removed all the wheels to check each bearing. The front offside disc hub had lateral play from side to side but not from top to bottom. I thought about tightening the bearing but I think these are sealed? The car got new front hubs and discs 22,000 miles and 3 1/2 years ago so I thought these should be fine.
The lateral movement seemed to be occuring inside the rubber gaiter and the CV joint. All the other components, springs, droplinks etc. looked OK.
I do almost all my own spanner work if only I could diagnose it properly. The car isn't worth much but pulls well with no other problems with it.
Nocturnal
Nocturnal
