I have a bizarre clutch issue. New clutch put in back in January. All good until 1 month ago. Clutch stuck down, won't change into gear when engine running, but will when off.
If you remove cap from fluid reservoir in engine, pump a few times, clutch and gears work again. Drive car about 30 miles and sticks again. Repeat above and it works.
It's been bled twice. No joy. No leaks either.
Thoughts?
Megane clutch sticks, but remove cap, pump and it works!
- Currently Drives:: 2004 renault megane 1.5 deisel
Re: Megane clutch sticks, but remove cap, pump and it works!
there is a vent hole in master cylider cap is it blocked
Users browsing this forum: Google [Bot] and 96 guests
