megane 1.5 diesel cold starting issues
- Currently Drives:: 2004 renault megane 1.5 deisel
starting the above megane currently impossible because a heater plug takes 15 to 20 seconds too do any good the problem is ya put start pad in follow the instructions push start button ingnition lights and glow plug light comes on 3 seconds the starter cuts in engine tries to fire starter senses overspeed and cuts out engine dont start is it any suprise . so grab ya partners hair drier disconnet intake pipe on hottest setting stuff it in the inlet hit the button and orf ya go down to boots for a new hair drier ,stood on it ya see . so anyone else noticed this prob and how to solve it ive a couple of ideas but it wont be astheticley pleasing (a pretty site)
Re: megane 1.5 diesel cold starting issues
the heater plugs should glow very quickly, are you sure they are all working good and have good contacts.
My 1.9 sometimes waits after start button pressed, but only 2-3 seconds.
lf the engine is a little tired or air in the system, that wouldn't help either.
Let us know how you get on with it.
Good luck
Bob.
Good luck
Bob.
- Currently Drives:: Megane II 1.9 dCi estate Megane II 1.5 dCi
Like the hair dryer idea know a few farmers that do that
Only a delay of 5 seconds or so for glow plugs yesterday and it was minus 3. Starts up straight away with a bit of smoke. Modern slim plugs don't need the 10-15s that the old Peugeots needed. Faulty glow plugs flag up a fault code usually on these but I would still check they are getting power. Not sure of it's location but there must be a control box with a temperature sensor that could have gone haywire...
