Hi, the EPS and ABS dash warnings keep coming up intermittently and when cornering. They go off with the ignition off/on. Fluid level seems to be ok. Will this be faulty/loose sensor? I had a replacement spring and ball joint stuff done recently, could this have caused it? It's puzzling because its intermittent so can't be a fuse? Many thanks. Mix.
Update: Just tried the OBD software and its giving C1041 and C10c3 codes. C1041 says it's front left sensor problem and it was the front left spring and ball joint where the work was done. So, its off to the garage to see what they say. Still, any advice would be welcome. Thanks.
ESP/ABS warning
- Currently Drives:: Megane 2's and a Grand Espace and a 330d m sport Touring
Re: ESP/ABS warning
Hi, just reading your earlier post and the subsequent discovery of those codes via the OBD reader. How did you get on with the garage as you were perhaps suspecting that a sensor had been damaged when the suspension work had been carried out?
