injection fault on display?????
my megane 1.9dci 03 keeps displaying injection fault with the service light on,it imediatly cuts out the engine but then starts again with no problems and no lights or faults on.I went to my local renault dealer who i advised that i had read that the fault could relate to glow plugs.He put the car on diagnostics and said this was not the fault as the plugs seem ok,he said it could be the fuel regulator or the the fuel sensor or the fuel pump or the crankshaft sensor???????all these parts are very expensive so is he taking the pish or what????Please help as renault cant without shafting me!!!!!!
its usually the plugs but can be a few things like that say. the plugs unfortunately are the cheapest fix, a lot of people have changed them with the message going away after. maybe take it somewhere else for a second opinion.
i have the same check ignition message, car still runs fine though but i'm gonna change the plugs and see if that gets rid of the message
just out of interest if you start it and the light comes on, leave it for a couple of minutes, stop it and restart. if the light doesnt come on then i'd hazard a guess at it being the plugs as they aren't really needed when the engine is warm so the light shouldnt come on
evening or is it morning!
well this is my first post on here and im having exactly the same problem today!!
my warning light for service is on , the display read check injectors but engine starts fine and runs fine - if i leave engine running for a while , switch off angine and start again the lights are off!!!
not getting the stop light come up but its very annoying and i have no idea what is wrong with it! just hoping its covered uder warranty....but chance of getting it to renault this week..none!
Good morning and welcome from all of us! What you are describing is a typical symptom of failed glow-plug. They are not used if the engine is hot. Replace all four -- it is cheaper than paying for the diagnostics to stealers. Then, the others usually fail soon after the first one. OEM glow plugs for 1.9DCi 120bhp are Beru GN 018, 0 100 226 373, GSF part No R18822, which I bought at £7 each from GSF. You can order them by phone.
Good luck.
Good luck.
