Well the time has come around yet again for the Mot test on my meg. Hopefully nothing too bad, Ive changed the pads checked everything as you would do and fingers crossed it should pass!!
Wish me luck for thursday!!
The "OLDIE" MOT test
- scoop
Kind Regards
Scoop
04 Megane Dynamique 1.6 VVT 16V / Cherished plate / In Black 5 door / Lexus lights, Mint!!
"Shut Ya mouth and give Ya Arse a chance"!
Scoop
- Stranger
- Currently Drives:: BMW X1
Re: The "OLDIE" MOT test
Good luck scoop, I'm sure everything will be fine
- nickbell69
Good luck Scoop. Hope your horn is loud enough
- robznet
Good look mate, a couple of valium will ease the anxiety! Only joking - I'm sure everything will be ok.
Let us all know how it went.
Rob
Rob
- scoop
Well for all those intrested it failed!!!! On a rear brake bulb!!! Can you belive it! As a few will know i have lexus clusters on the back with LED brake bulbs (All BS standard I hasten to add!) Well the LED had failed and the dealer was going to charge me £75 for dianostics as they wouldnt touch the "none renault" light cluster! and they refused to change the bulb for me with a standard one which meant I had to have a retest at a later date! I drove home replaced the LED with a spare and rang back to ask them to check it. "oh it will be Monday before we can retest it" So I kicked off, basically all they had to do was check that the bulb was replaced and working correctly which it was. The lady went away and said I will speak with the technican. She came back and said if you bring it back today they will see what they can do but I would have to wait as they were very busy! I took it back and checked it again and it passed strangley enough!!! Hehe
I cant believe I forgot to check it before. Normally I go right over the car to make sure everything is ok, still its done now for another year and i can laff at the cheers in the garage from the other mecanics when they tested my air horn!!!
Kind Regards
Scoop
Scoop
- nickbell69
Nice one Scoop thats a result. Pity about the customer service though or lack of it. It's shocking when you have to kick up a fuss just to get a light checked out. If you'd waited till Monday they'd probably have managed to charge for a retest.
- robznet
Nice one scoop - glad to know you got it through (eventully)!
Rob
Rob
