High level 3rd brake light not working
The section for all Megane I talk.
Riknos
Postby Riknos » Wed May 24, 2017 2:26 pm
Any ideas what it could be? The bulb has been changed but still not working. I'm assuming it won't have its own separate fuse? Is there a common part that goes wrong or do i need to strip the interior to find a kinked wire somewhere?
Thanks!
jamesjupp
Currently Drives:: renault megane 1 coupe - 2000 - 1.6 16v
Re: High level 3rd brake light not working
Postby jamesjupp » Sat Nov 14, 2020 8:01 am
get a multimeter and check the earth first, see if its got power and earth, go from there.
it is probably powered from one of the rear clusters, so it shouldnt be hard to find the issue.
Its *probably* a bad bulb holder? give it a rub with some sandpaper where it should make contact.
Return to “Megane I”
Users browsing this forum: No registered users and 59 guests
