High level 3rd brake light not working
Posted: Wed May 24, 2017 2:26 pm
by Riknos
Any ideas what it could be? The bulb has been changed but still not working. I'm assuming it won't have its own separate fuse? Is there a common part that goes wrong or do i need to strip the interior to find a kinked wire somewhere?
Thanks!
Re: High level 3rd brake light not working
Posted: Sat Nov 14, 2020 8:01 am
by jamesjupp
get a multimeter and check the earth first, see if its got power and earth, go from there.
it is probably powered from one of the rear clusters, so it shouldnt be hard to find the issue.
Its *probably* a bad bulb holder? give it a rub with some sandpaper where it should make contact.
