Tyre Pressure Monitor
The section for all Megane I talk.
Gbhec
Postby Gbhec » Tue Jul 09, 2019 8:34 pm
I own a Renault Megane Cabriolet Privilege plus mk 1 - 2002.
When i go over approximately 40mph the tyre warning light illuminates and flashes in the display (no other warning lights) and the 4 tyres are blanked out from the car graphic.
I have checked the tyre pressures and all are as the manual.
I have reset the tyre pressure monitoring system by removing and replacing the battery connection which brings back the 4 wheels on the graphic and extinguishes the light in the display. However on going above 40mph the same issue occurs.
My local garage have carried out a code read and have found no error codes. My local tyre garage has no other qay to diagnose the problem without replacing all the parts.
I would be grateful if anyone could confirm what is happening and how i can diagnose it.
Gbhec
Re: Tyre Pressure Monitor
Postby Gbhec » Tue Jul 16, 2019 8:13 pm
Be great to hear back if anyone has some ideas!
Return to “Megane I”
