And my check emissions light is apparently some flap sticking shut in the exhaust. I assume this is part of the DPF
The dealer is checking to see if this is under the approved used warranty, or whether the sale dept will cover this, but hopes are not high.
No idea on the cost involved, but I'll push for a contribution from Renault, but it sucks to have all these problems in under a year.
Check Emmissions 1.5 DCi
- Currently Drives:: 2012 Renault Megane 1.5 DCI Coupe
Re: Check Emmissions 1.5 DCi
They've covered 'it' under warranty I'm surprised though as the Renault approved warranty excludes the exhaust system.
Although I'm not sure if'its just been cleaned up or a new part fitted.
It seems that despite buying an used Renault from a Renault main dealer, that its not covered with an approved used Renault warranty.
On the upside it covered the new exhaust air flap, the downside is it doesn't cover diagnostics for the satellite controls.
It also fixed the temperature gauge as well. It still takes its time to heat up, but now stays at temperature. The malfunction was probably screwing the running as there were a handful of DTCs.
Users browsing this forum: Google [Bot] and 1 guest
