Hey, guys.
I have a 59-plate Mégane Coupe, and the rear nearside brake light doesn't seem to be illuminating anymore. I've bought a pair of bulbs, and I thought it would be an easy job: I looked in the manual, and it says to unscrew the two nuts on the inside & the one screw on the outside and then pull the unit out. Unscrewing the nuts and the screw was easy - but it seems that there is still something holding the cluster in-place when it comes to pulling it out.
I've had a look around on both Google and YouTube - but all of the videos are for five door models. I've provisionally booked it in at a Renault dealer near me for tomorrow - but I've since read-up that it can cost extortionate amounts when done at a dealer. There is, obviously, the option of Halfords - but I'm even skeptical about that (as it says their rear bulb change costs are FROM £5 - meaning it can only go up).
Has anyone else encountered this issue before? If so - is it just a case of pulling a bit harder, or have I missed something?
Thanks very much
Changing Rear Bulb
- Currently Drives:: 2009/59 Mégane 1.6 Coupe; 2006/55 Hyundai Coupe SE.
Re: Changing Rear Bulb
There is a bulb end stud that goes into a rubber gromit to locate it.
Pull straight back it will be a little stiff.
Steve
Steve
Undo the screws and pull .... hard
Users browsing this forum: Google Adsense [Bot] and 9 guests
