Hi folks,
Picking up a 2013 Megane "knight" edition on Wednesday. One thing it's missing that I would have liked was integrated nav.
I've had a look around and seen that it looks fairly hard verging on impossible to retrofit OEM Tomtom equipment.
To this end, what other options are there for a fully integrated install?
Are there any after market units worth getting?
The wife isn't overly keen on a portable unit. I've got her used to the integrated set up on the X3 now
Integrated Satnav Options
Re: Integrated Satnav Options
Spectacular response....
If anyone wants to know what seems to be the best solution...
I found a mobile App called Waze that can be used in conjunction with spotify. This means that when my mobile is sync'd to the cars BT connection the navigation becomes integrated through the car.
I can listen to music on Spotify and it will lower the music volume and give me commands as I drive like a fully integrated system.
Obviously it only works when the phone is sync'd and the car is set to media rather than Radio or CD, which in turn means I can then only listen to spotify.
Then again, that's better than Radio 1.
