hi
have just bought 2010 renault megane 1.6 petrol
when you unlock car you can turn heater blower on turn air con on and turn wipers on without putting keycard in to start
is this normal or is there a fault
also when car has been running and you take keycard out you can have above all running until to lock doors then they turn off
i had a mk 2 megane and they all used to turn off when you opened drivers door
heater switch and wipers
- Currently Drives:: Mark 3 Megane sports tourer auto
Re: heater switch and wipers
Hi Sooty,
It sounds like you have a vehicle with the "hands free" keycard. You can test this by just walking up to the car with the card in your pocket. Pull the door release and it should unlock. It is not necessary to put the card in the slot - just leave it in your pocket and press the start button. When you stop and press the stop/start button things remain active until you open a door. Close the door and walk away and the car will lock itself.
Hope this helps.
Candaer
Hope this helps.
Candaer
