Hi All,
It appears that I have a problem with the switch that operates the folding roof.
If I press the switch then nothing happens, unless I waggle the wires behind the switch by inserting my fingers through the gap for the handbrake!
Any ideas how to get this console apart so I can actually get a full look at the switch?
any help would be welcome
Roof Switch problems
Re: Roof Switch problems
Hi
Open the center consul lid and you can then "pop" off the front panel, it is held in place by spring clips it can then be slid upwards as it is slotted for the handbrake.
Hi did you manage to fix it? As I'm having the same problem with mine.
Thanks Anth.
Thanks Anth.
Users browsing this forum: Bing [Bot] and 11 guests
