Alarm randomly going off
- Currently Drives:: Renault megane mark 2 1.6 petrol vvt 2005 plate
Hi guys new here, I've just got a 55 plate renault megane cabriolet, but the alarm has started to randomly go off, I can temporarily disable it by pushing the button 5 times, but I don't wanna do that every time I lock my car, I've read that putting foil over the volumetric sensors should work, but would this work on mine? My sensors are on the piller next to the windscreen, anyone out there that can help? Thanks in advance leanne x
- Currently Drives:: Mazda 6
Renault Megane convertible
Re: Alarm randomly going off
Did you get it sorted cos ive got exactly the same problem
Press and hold the central lock button for 5-7 seconds after opening the door until it clunks.
When you shut the door all doors lock, no alarm.
Bonnet sensor is a usual culprit mine started this so I poped bonnet and pressed and released the pin so it sprang back with some force did the 3/4 times after this assault on the pin it has behaved since. If it has always done this bonnet might need pulling down a bit tighter you could try a bit of cardboard taped to bonnet where pin is shut it n lock it and see if it goes off.
I just stuck bluetac over the interior sensors
Bluetack.....
Outstanding would never have thought that!
Is that now a thousand AND one things to do with bluetack.....
Nice one.
Nice one.
Users browsing this forum: No registered users and 27 guests
