trying a new approach, whether putting the roof up or down, i don't get the "beep beep beep" confirmation noise, which i think also cuts the power to the pump?
even when shutting, the pump still tries pumping even though the roof is shut, same when opening, is there a sensor that needs replacing?
so when driving off, with roof up or down, the car starts beeping at me for a while, but no message comes up on the instrument cluster.
any help very welcome, i can't have been the only person this has happened to, surely?
roof "beep beep beep"
- Currently Drives:: kia Optima
Citroen C3 Pluriel
Renault Megane CC
Citroen C3 Pluriel
Renault Megane CC
Re: roof "beep beep beep"
just had an interesting chat to an AA chap, told him symptoms of car beeping away, then told him about the new switch/catch i fitted to the rear lid, and he suggested that the switch may now needed to be coded to the car? i have heard this before about certain new parts being fitted to cars, but didn't think something like that switch would need this?
- q292u
- Global moderator
It wouldn't surprise me if he was correct.. Unfortunately that sounds like a Renault dealer job (Sharp intake of breath)
Citroen C3 Pluriel
Renault Megane CC
i can't be the only one that this has happened to?
Try deleting any warnings from ecu if that does not work and ecu re set to force ecu to re-learn parameters.
Remember conversation we had about my egr valve we had to get into ecu and into egr and delete data forcing ecu into a learning process. Quite a lot of steps for what should be a simple process but apparently in some cars its not.
Do know volvo come with blank switches and have to be told by the factory which switch it is. Didn't think renault did this so might just be a re learn issue
Citroen C3 Pluriel
Renault Megane CC
spoke to Renault today, and he said its unlikely that it would need coding, but he did say it might pay to have it checked out with what i believe is Renaults equivalent to a body control unit ?, can't remember what he called it, UHC or something or other
Citroen C3 Pluriel
Renault Megane CC
ChrisM wrote:Try deleting any warnings from ecu if that does not work and ecu re set to force ecu to re-learn parameters.
what did you use to get into it bud?
The renault diag software the name eludes me at mo keep thinking planet and odis but wrong brands diaologies but I thinks thats parts catalogue just cant think of its name....
Your snapon code readers and aftermarket diags dont get deep enough we tried to snapon boxes 1st both rather expensive bits of kit so my renault man had to dig out his old renault laptop charge it and try.
It seems the renault software reads more and allows you to do more which he openly admited he had forgotten.
It will come to me but its there own diag software.
