waterleak.
waterleak.
anybody have a fix for drip onto front seat from the joint in the seal at top of A post? window seems to seat ok into its seal, the roof looks to close tight but i still have a drip on passenger side, any adjustments that can be made?
Re: waterleak.
Mine leaked from her for about 3 years. Made sure drain was clean with curtain wire, krytoxed and cleaned seals nope! Still let water in.
Then it blew a hydraulic lock pipe so had it replaced now roof does not leak... wierd as the parts replaced had nothing to so with the seals it was internal trims removed seals left in place.
Looks like it fixed itself! Now how many people can say that about renault?
Just make sure seals r clean and drain off is clear.
Re: waterleak.
well after the massive response to my posting i will update you all. iv cleaned allthe rubbers and joints with tfr and given a good rinse off, all leaks now cured. must be down to muck on the rubber contact surface.
Re: waterleak.
Unfortunately you will never get a massive responce on here for a technical question at a guess I would say most owners on here would not know which end of a hammer to use to change a set of points on thier diesel engine. I think most get garaged when they break.
But I did come back and say clean seals and drains also use a rubber treatment I use the vw one krytox as it has a "plumping" agent basically if it works on an eos it'll work on anything.
- q292u
- Global moderator
Re: waterleak.
You need to bear in mind that most forum users don't have a CC, so we don't have a leaky roof, just leaky everything else!
Most forum users don't even look in the CC section.
Re: waterleak.
Mmmm good point at one time it use to be quite popular always new posts but not these days wonder where they have all gone. Especially considering there are still a fair few CC on the road mk2 & 3s
